Dyn X Speaker Mount image number 0
Dyn X Speaker Mount image number 1
Dyn X Speaker Mount image number 2
Dyn X Speaker Mount image number 3
Dyn X Speaker Mount image number 4
Dyn X Speaker Mount
Dyn X Speaker Mount
Dyn X Speaker Mount
Dyn X Speaker Mount
Dyn X Speaker Mount
Dyn X Speaker Mount
Flexible Adjustment
360-degree adjustable design allows for ultimate flexibility.
High Build Quality
An aluminum alloy and stainless steel build allow for long hours of use.
  • Speaker Mount Material Aluminum Alloy / Stainless Steel (joint)
  • Speaker Mount Dimensions A: 85 mm
  • Speaker Mount Dimensions B: 150 mm
  • Speaker Mount Dimensions C/C2: ¼ thread
  • Speaker Mount Dimensions D: Straight / Standard Knurl ¼
  • Speaker Mount Dimensions E/E2: 12 mm
  • Speaker Mount Dimensions G/G2: 18.5 mm
  • Speaker Mount Dimensions H: 17.3 mm
  • Speaker Mount Dimensions I: 40 mm
