Dyn X Quick Release image number 0
Dyn X Quick Release image number 1
Dyn X Quick Release image number 2
Dyn X Quick Release image number 3
Dyn X Quick Release image number 4
Dyn X Quick Release
Dyn X Quick Release
Dyn X Quick Release
Dyn X Quick Release
Dyn X Quick Release
Dyn X Quick Release
Seat Adjustment
A simple and tool-less seat adjustment solution in addition to the seat slider allows for customization without sacrificing haptic feedback.
High Durability
Comes with a tough, stainless-steel handle capable of withstanding applied pressure.
  • Quick Release Material Stainless Steel
  • Quick Release Dimensions D: M8
  • Quick Release Dimensions D1: 10 mm
  • Quick Release Dimensions D: 22 mm
  • Quick Release Dimensions A: 80 mm
  • Quick Release Dimensions A1: 92 - 93 mm
  • Quick Release Dimensions B: 25 mm
  • Quick Release Dimensions B1: 17 mm
  • Quick Release Dimensions H: 22 mm
  • Quick Release Dimensions H1: 32 mm
  • Quick Release Dimensions L: 20 - 21 mm
