Thermal grease CryoFuze 7
Introducing CryoFuze 7, our all-new line of thermal pastes. Available in both 2g and 4g amounts, CryoFuze 7 utilizes nanoparticles to allow for excellent thermal conductivity and heat transfer on all processing components.
Noncorrosive Formula
Low Thermal Impedance
Anhygroscopic Composition
Eco-Friendly Packaging
Utilizing nanoparticles, CryoFuze allows for excellent thermal conductivity on all processing components for optimal heat transfer.
With thermal impedance of 0.03C*cm2/w, CryoFuze 7 greatly improves overall performance
CryoFuze 7 also has a versatile range of temperature performance, maintaining stability from -50°C up to 250°C. All of this is contained in an eco-friendly, environment-first package.
Viscously balanced formula allow for easy application and clean up.
Designed with the environment in mind, CryoFuze 7’s packaging reduces waste
The page you're looking shows Cooler Master contents for Australia.
