Cosmos GOLD Limited Edition image number 0
Cosmos GOLD Limited Edition image number 1
Cosmos GOLD Limited Edition image number 2
Cosmos GOLD Limited Edition image number 3
Cosmos GOLD Limited Edition image number 4
Powerful & Unlimited Creativity
• Last generation AMD X3D processor
• Custom Made CM Nvidia RTX 5090 32GB
• Ultra Premium COSMOS Gold case
• High-performance, scalable cooling system
• 64 GB DDR5 on board
A selection of unique components
Fitted with a Cooler Master-designed version of NVIDIA's RTX 5090 Cooler Master Edition, based on the cutting-edge Blackwell architecture, this PC represents a significant leap forward in performance, delivering impressive frame rates even at the highest resolutions and settings.
Performance in Perfect Fit
Provides generous components clearance to enable high-performance.
Upgrade Made Easy
Unlock the full potential of your high-performance system with the X870E motherboard and enjoy guaranteed future-proof scalability.
Cold As Ice
Thanks to the use of a liquid cooler and high-end fans, your PC delivers exceptional thermal performance... keeping your new PC cool and quiet.
  • CPU AMD Ryzen 9 9950X3D2 (16 cores / 32 threads) - Max Speed 5.6Ghz
  • Motherboard ASUS ROG CROSSHAIR X870E HERO
  • RAM 64 DDR5 (4x16 GB)
  • Graphic Card Support Exclusive Cooler Master NVIDIA GeForce RTX 5090 32GB
  • SSD SSD 2To Gen 4.0
  • PSU Cooler Master X Mighty 2000 Watts (Platinum)
  • Case Cosmos Gold limited Edition
  • Cooling AIO : Cooler Master ATMOS II 360 VRM FAN, Back : 1 x location for 120mm, Front : 2 x 200mm (included)
  • IO Data connectors 4 x USB 3.2 Gen 1 Type-A 5G + 2x USB 3.2 Gen 2x2 Type C 20G
  • IO Audio connectors Audio In / Out Jack 3.5mm, (Audio + Mic)
  • Video connectors Display Port 2.b (x3) - HDMI 2.1b (x1)
  • Ethernet connector RJ45 + Wifi 7
  • Operating System Windows 11 Home Edition
  • Accessories provided Power cable + Extra ATMOS II Flex KIT LCD
  • Dimensions Incl. Protrusions 669 x 330 x 639 mm, Excl. Protrusions 579 x 260 x 582 mm
  • Weight 45KG
  • EAN 4719512169773
