CK721 Sakura Limited Edition image number 0
CK721 Sakura Limited Edition image number 1
CK721 Sakura Limited Edition image number 2
CK721 Sakura Limited Edition image number 3
CK721 Sakura Limited Edition image number 4
CK721 Sakura Limited Edition image number 5
CK721 Sakura Limited Edition image number 6
CK721 Sakura Limited Edition image number 7
CK721 Sakura Limited Edition image number 8
CK721 Sakura Limited Edition image number 9
CK721 Sakura Limited Edition image number 10
CK721 Sakura Limited Edition image number 11
CK721 Sakura Limited Edition image number 12
Your Everyday PC Carry
The CK721 Sakura Limited Edition wireless mechanical keyboard is a hassle-free workhorse, a no-fuss keyboard for both work and play.
  • Product Keyboard
  • Keyboard Material Plastic
  • Charging Support Wired charging
  • Keyboard Response Time 1ms (Wired/2.4GHz Mode)
  • Battery Life 73hrs (LED Off)
  • Keyboard Response Time 8ms (Bluetooth Mode)
  • Keyboard Multimedia Key Through Function Key (FN)
  • Connectivity Wired
  • Connectivity 2.4 GHz
  • Keyboard Material Aluminum
  • Keyboard Polling Rate 125Hz (Bluetooth Mode)
  • Compatible OS Windows 8+
  • Battery 2000mAh
  • Connectivity Bluetooth 5.1
  • Compatible OS Mac OS X 10.10+
  • Keyboard Polling Rate 1000Hz (Wired/2.4GHz Mode)
  • Software Support Cooler Master MasterPlus+
  • Compatible OS Android
  • Wrist rest Cloth/SBR, 334 x 95 x 18 mm
  • Compatible OS iOS
  • Keyboard LED Color RGB, 16.7 million colors
  • Keyboard Cable 1.8m
  • Keyboard Cable USB Type C to Type A
  • Keyboard Color Special Design for Sakura edition
  • Keyboard Cable Detachable & Braided
  • On-the-fly System Yes
  • Keyboard Keycaps PBT Double-Shot
  • Keyboard Dimensions (L x W x H) Standard: 334 x 118 x 37 mm / 13.15 x 4.65 x 1.46 inches
  • Keyboard Dimensions (L x W x H) With 1st stage feet open: 334 x 118 x 43 mm / 13.15 x 4.65 x 1.69 inches
  • Keyboard Dimensions (L x W x H) With 2nd stage feet open: 334 x 118 x 46 mm / 13.15 x 4.65 x 1.81 inches
  • Keyboard Weight 764g / 1.68 lbs (without Cable & Dongle)
  • Keyboard Switch Type TTC Mechanical Switch (Red/Blue/Brown)
  • Product Number CK-721-SKTR2/L2/M2-US
