Caliber X1C Gaming Chair image number 0
Caliber X1C Gaming Chair image number 1
Caliber X1C Gaming Chair image number 2
Caliber X1C Gaming Chair image number 3
Caliber X1C Gaming Chair image number 4
Caliber X1C Gaming Chair image number 5
Caliber X1C Gaming Chair image number 6
Caliber X1C Gaming Chair image number 7
Caliber X1C Gaming Chair image number 8
Caliber X1C Gaming Chair image number 9
Caliber X1C Gaming Chair image number 10
Caliber X1C Gaming Chair image number 11
Caliber X1C Gaming Chair image number 12
Caliber X1C Gaming Chair image number 13
Caliber X1C Gaming Chair image number 14
Caliber X1C Gaming Chair image number 15
Caliber X1C Gaming Chair image number 16
Caliber X1C Gaming Chair image number 17
Get ready to One Hit Knock-out (OHKO) the competition from the comfort of your breezy Caliber X1C!
Buy Now
  • Product Number CMI-GCX1C-GY, CMI-GCX1C-BK
  • Color Gray / Black
  • Total Height Range 130-138 cm / 51.2"-54.3"
  • Backrest Height 86 cm / 33.9"
  • Backrest Width 58 cm / 22.8"
  • Armrest to Armrest 72 cm / 28.3"
  • Seat Width (including sides) 54 cm / 21.3"
  • Sitting Area 54 cm / 21.3"
  • Seat Depth 54 cm / 21.3"
  • Diameter of Base 70 cm / 27.6"
  • Metal Plate Thickness 1.5 mm
  • Armrest Adjustability 30-37 cm / 11.8"-14.6"
  • Floor to Seat Top 50-58 cm / 19.7"-22.8"
  • Height Adjustability 8 cm / 3.1"
  • Armrest Width Adjustability 1.5 cm / 0.6"
  • Recline 90-180 degree
  • Armrest 4D (lift, sway, swivel, forward)
  • Headrest Ergonomic Pillow
  • Extra Padded Backrest Built-in pillow (hidden stripes)
  • Surface Material Eco-friendly fabric (Non toxic polyester) on front
  • Inner Material Cold molded foam
  • Frame Material Steel
  • Base (leg) Aluminum
  • Caster 75 mm / 3.0"
  • Gas Lift Class 4
  • Net Weight 24.7 kg / 54.5 lbs
  • Gross Weight 29.0 kg / 63.9 lbs
  • Max. Weight Load 150 kg / 330 lbs
  • Product Gaming Chair
  • Chair Type Cooling Series
  • Chair Type Caliber X1 Series
