Caliber R2C Gaming Chair image number 0
Caliber R2C Gaming Chair image number 1
Caliber R2C Gaming Chair image number 2
Caliber R2C Gaming Chair image number 3
Caliber R2C Gaming Chair image number 4
Caliber R2C Gaming Chair image number 5
Caliber R2C Gaming Chair image number 6
Caliber R2C Gaming Chair image number 7
Caliber R2C Gaming Chair image number 8
Caliber R2C Gaming Chair image number 9
Caliber R2C Gaming Chair image number 10
Caliber R2C Gaming Chair image number 11
Caliber R2C Gaming Chair image number 12
Caliber R2C Gaming Chair image number 13
Caliber R2C Gaming Chair image number 14
Caliber R2C Gaming Chair image number 15
Caliber R2C Gaming Chair image number 16
Stay Cool In The Heat Of Battle
Keep your cool in all situations and claim your victory from the command of your R2C!
Buy Now
  • Product Number CMI-GCR2C-GY, CMI-GCR2C-BK
  • Color Gray, Black
  • Total Height Range 125.5-133.5 cm / 49.4"-52.6"
  • Backrest Height 82 cm / 32.3"
  • Backrest Width 58 cm / 22.8"
  • Armrest to Armrest 71 cm / 28.0"
  • Seat Width (including sides) 58 cm / 22.8"
  • Sitting Area 38 cm / 15.0"
  • Seat Depth 54 cm / 21.3"
  • Diameter of Base 70 cm / 27.6"
  • Steel Plate Thickness 1.2 mm
  • Armrest Adjustability 28.5-36.5 cm / 11.2"-14.4"
  • Floor to Seat Top 48-56 cm / 18.9"-22.0"
  • Height Adjustability 8 cm / 3.1"
  • Recline 90-180 degree
  • Armrest 2D
  • Headrest Ergonomic Pillow
  • Lumbar Support Ergonomic
  • Surface Material Eco-friendly fabric (Non toxic polyester) on front
  • Inner Material Backrest cut foam, Seat cold molded foam
  • Frame Material Steel
  • Base (leg) Steel
  • Caster 60 mm / 2.4"
  • Gas Lift Class 4
  • Net Weight 21.5 kg / 47.4 lbs
  • Gross Weight 25.6 kg / 56.4 lbs
  • Max. Weight Load 150 kg / 330 lbs
  • Product Gaming Chair
  • Chair Type Cooling Series
  • Chair Type Caliber R2 Series
