Caliber R1S CAMO Gaming Chair image number 0
Caliber R1S CAMO Gaming Chair image number 1
Caliber R1S CAMO Gaming Chair image number 2
Caliber R1S CAMO Gaming Chair image number 3
Caliber R1S CAMO Gaming Chair image number 4
Caliber R1S CAMO Gaming Chair image number 5
Caliber R1S CAMO Gaming Chair image number 6
Caliber R1S CAMO Gaming Chair image number 7
Caliber R1S CAMO Gaming Chair image number 8
Caliber R1S CAMO Gaming Chair image number 9
Caliber R1S CAMO Gaming Chair image number 10
Caliber R1S CAMO Gaming Chair image number 11
Caliber R1S CAMO Gaming Chair image number 12
Caliber R1S CAMO Gaming Chair image number 13
Caliber R1S CAMO Gaming Chair image number 14
Caliber R1S CAMO Gaming Chair image number 15
Caliber R1S CAMO Gaming Chair image number 16
Caliber R1S CAMO Gaming Chair image number 17
Caliber R1S CAMO Gaming Chair image number 18
Caliber R1S CAMO Gaming Chair image number 19
Caliber R1S CAMO Gaming Chair image number 20
Caliber R1S CAMO Gaming Chair image number 21
Caliber R1S CAMO Gaming Chair image number 22
Caliber R1S CAMO Gaming Chair image number 23
Caliber R1S CAMO Gaming Chair image number 24
Caliber R1S CAMO Gaming Chair image number 25
Caliber R1S CAMO Gaming Chair image number 26
Caliber R1S CAMO Gaming Chair image number 27
Caliber R1S CAMO Gaming Chair image number 28
Caliber R1S CAMO Gaming Chair image number 29
Caliber R1S CAMO Gaming Chair image number 30
Caliber R1S CAMO Gaming Chair image number 31
Caliber R1S CAMO Gaming Chair image number 32
Caliber R1S CAMO Gaming Chair image number 33
Caliber R1S CAMO Gaming Chair image number 34
Caliber R1S CAMO Gaming Chair image number 35
Caliber R1S CAMO Gaming Chair image number 36
Caliber R1S CAMO Gaming Chair image number 37
Caliber R1S CAMO Gaming Chair image number 38
Caliber R1S CAMO Gaming Chair image number 39
Caliber R1S CAMO Gaming Chair image number 40
Caliber R1S CAMO Gaming Chair image number 41
Caliber R1S CAMO Gaming Chair image number 42
Caliber R1S CAMO Gaming Chair image number 43
Caliber R1S CAMO Gaming Chair image number 44
Caliber R1S CAMO Gaming Chair image number 45
Caliber R1S CAMO Gaming Chair image number 46
Caliber R1S CAMO Gaming Chair image number 47
It's Time To Level Up
Gain more XP, no more muscle stiffness! With an ergonomic design and premium PU material, Caliber R1S is your perfect match for long hours of missions
Buy Now
  • Product Number CMI-GCR1S-PRC, CMI-GCR1S-BKC, CMI-GCR1S-PKC
  • Color CM CAMO, Dark Knight CAMO, SAKURA CAMO
  • Total Height Range 125-133 cm / 49.2"-52.4"
  • Backrest Height 82 cm / 32.3"
  • Backrest Width 57 cm / 22.4"
  • Armrest to Armrest 75 cm / 29.5"
  • Seat Width (including sides) 53 cm / 20.9"
  • Sitting Area 37 cm / 14.5"
  • Seat Depth 57 cm / 22.4"
  • Diameter of Base 70 cm / 27.6"
  • Steel Plate Thickness 1.2 mm
  • Armrest Adjustability 28-36 cm / 11.0"-14.2"
  • Floor to Seat Top 45-53 cm / 17.7"-20.9"
  • Height Adjustability 8 cm / 3.1"
  • Recline 90-180 degree
  • Armrest 1D, 2D (Rose White)
  • Headrest Ergonomic Pillow
  • Lumbar Support Ergonomic
  • Outer Material Perforated PU
  • Inner Material Backrest: cut foam, Seatbase: cold molded foam
  • Frame Material Steel
  • Base (leg) Nylon
  • Caster 60 mm / 2.4"
  • Gas Lift Class 4
  • Net Weight 21.5 kg / 47.4 lbs
  • Gross Weight 24 kg / 52.9 lbs
  • Max. Weight Load 150 kg / 330 lbs
  • Warranty 1 year
  • Product Gaming Chair
  • Chair Type Caliber R1 Series
