12VHPWR Adapter Cable image number 0
12VHPWR Adapter Cable image number 1
12VHPWR Adapter Cable image number 2
12VHPWR Adapter Cable image number 3
12VHPWR Adapter Cable image number 4
12VHPWR Adapter Cable image number 5
Powering The Next Generation With Ease
• 90 degree orientation
• Highly flexible cables
• Three 8-pin connectors
• 40 series GPU support
• Full PSU compatibility
40 SERIES READY, ATX 3.0 NOT REQUIRED
Recommended installation
• Do not use cables that do not comply with the standard configuration.
• Do not use with additional adapter cables (e.g. 8-pin to 6+2-pin, SATA, etc.).
• Do not put the cables near any heat sources.
FULL psu compatibility
type 1
12VHPWR adapter cable
type 2
  • Color Black
  • Cable Type Single Sleeve
  • Wire Gauge 16 AWG (Power) / 28 AWG (Signal)
  • Length 65cm
  • Cable Clip Numbers 1x 12+4 Pin (x1)
  • Cable Clip Numbers 3x 8 Pin
  • Connectors 1x 12+4 Pin
  • Connectors 3x 8 Pin
  • Series Cable
  • Series Accessories
  • Model CMA-NFPC16XXBK* Ver.GL
