1-to-3 RGB Splitter Cable image number 0
1-to-3 RGB Splitter Cable image number 1
1-to-3 RGB Splitter Cable image number 2
1-to-3 RGB Splitter Cable image number 3
1-to-3 RGB Splitter Cable image number 4
1-to-3 RGB Splitter Cable image number 5
1-to-3 RGB Splitter Cable image number 6
1-to-3 RGB Splitter Cable image number 7
1-to-3 RGB Splitter Cable image number 8
1-to-3 RGB Splitter Cable image number 9
Expand It as You Will
  • Cable Material PVC
  • Pin Contact Material Brass
  • Total Length 58cm
  • Connector Type 4-pin (12V,G,R,B)
  • Connector Withstanding Voltage 300 V (min)
  • Pin Rated Current 3A
  • Pin Operation Temperature -40°C -105°C
  • Color Black
  • Cooler Type RGB Accessories
  • Series RGB Accessories
  • EAN code 4719512059890
  • UPC code 884102032554
  • Product Number R4-ACCY-RGBS-R2
